I want to try using HeadAC3che to Create my audio instead of TMPGEnc. How do I join that video and audio stream to one file.
You need to multiplex them. Personally I think bbmpeg is the only truly compliant program for multiplexing svcd compliant mpeg2 files but TMPGenc will work also. Look in file/mpeg tools/simple multiplex. Load your audio and video streams and hit run.
If you choose to use bbmpeg, which I suggest you do, then follow this guide. http://www.vcdhelp.com/bbmpegedit.htm Its a cutting guide but just ignore the part where you set your cut points.
joining mp4 files but audio out of sync
By Liselotte in forum Newbie / General discussionsReplies: 2Last Post: 1st Aug 2011, 21:18 -
joining AC3 5.1 audio
By avengerevenge in forum Newbie / General discussionsReplies: 3Last Post: 17th Dec 2010, 11:02 -
Converting, cutting, and joining audio files in an only software!?
By coxanhvn in forum AudioReplies: 4Last Post: 22nd Feb 2008, 23:44 -
Joining audio from 2 differant sources
By kshavo in forum AudioReplies: 2Last Post: 6th Nov 2007, 09:34 -
Joining 2 avi files, error with audio streams, need help
By leinan in forum Newbie / General discussionsReplies: 5Last Post: 8th Jul 2007, 06:12
