any help would be appricated. I need to filter the hissing noise in a video.
Results 1 to 11 of 11
Just go inot Virtual Dub, open up the file, then goto File-> save WAV. You can find virtual dub in the tools section of this site.
I will not eat oysters. I want my food dead - not sick, not wounded - dead.- Woody Allen
fonoop.com -
Load the AVI into www.goldwave.com and use one of the filters. Goldwave download also has MP3 plug-ins on the download page.Originally Posted by hardbody6pack
Save out the WAV ready for use later, matching the source type.
Or use Vdub to save out the audio uncompressed at 44.1Khz then use that in Goldwave to remove hiss -
I'm having problem with Goldwave removing the hiss. It tells me to set the horizontal line at 75 and chose filter hiss, but once it goes through the whole process, I still have noise in there, but not a hiss anymore, it's different kind of disturbance. Am I doing it right?
Did you try the noise reduction function in Gold Wave?
Hello. -
Yes,that's what I was using, but I tried nero wave editor and it was real simple and worked. Now I just have to figure out how to multiplex the video and the audio..???
If your making a VCD, just use TMPGEnc
Audio > WAV
Video > AVI
Or Vdub, Load AVI then select Audio > Wave audio -
I think I'm a little confused. To put the audio and video back together is called De-multiplixing or multiplexing? I need to join them together!!
Putting them together is multiplexing. On the main screen in TMPGEnc, once you tell the program what video and audio inputs you will be using and what to name the output file. once you select "Start", you will be multiplexing.
Hello. -
I think I finally did it. Please look at my latest post in this forum. Need your input please.
How to Extract /Convert RMVB Audio Files to MP3 or WAV?
By devilcoelhodog in forum AudioReplies: 6Last Post: 28th Dec 2011, 11:07 -
convert from ezonics Live Express .exe to some other video format, extract
By johnyb1 in forum Video ConversionReplies: 3Last Post: 14th Jul 2009, 23:07 -
Isolate Audio In This MPEG-2 File, And Save As WAV (or any other format)
By onesikgypo in forum AudioReplies: 0Last Post: 22nd Feb 2009, 05:14 -
Extract audio to WAV using VirtualDubMod
By jimmalenko in forum User guidesReplies: 15Last Post: 14th Nov 2007, 03:42 -
capturing audio on PC to MP3 or WAV format, which software ?
By ktnwin in forum AudioReplies: 3Last Post: 2nd Nov 2007, 05:13
