I'm using AE(adobe after effects) 5.5 on OS 10.1.5 and a G4 powerbook. With PAL footage(25fps).
Ok I'm playing one layer at comp speed 25fps, layer 1. I have another layer I've time stretched and I've split that layer, layers2 and 3. I have enabled frame blending and checked layers 2 and 3.
Ok. Now in the comp, layer 1 is playing and then I fade in 2 and 3. Then I fade all three clips out. I add to the render queue. Make all the setting including frame blending for checked layers in the render setting.
When I play the quicktime movie it's running fine then as soon as the footage on layers 2 and 3( one original layer time stretched and split into two) starts the movie slows down.
I obviously dont want this and any help would be great.
later.
try premiere for video editing after fx is not made for doing that although it can it,s not very good at it
Time Stretch VIDEO, like "Change Tempo" in Audacity - Software? H
By djmoon in forum EditingReplies: 14Last Post: 18th Nov 2013, 14:47 -
Stretch mp4?
By yams in forum Video ConversionReplies: 0Last Post: 13th Nov 2010, 20:49 -
can i stretch this video?
By uglijimus in forum Video ConversionReplies: 9Last Post: 9th Oct 2009, 23:02 -
Stretch conversion
By blueleo65 in forum Video ConversionReplies: 15Last Post: 6th Jul 2009, 11:35 -
Speed Correction (Time Stretch) In Audition.... Few Q's
By Liquid Drum Theater in forum AudioReplies: 11Last Post: 25th Aug 2007, 11:41
