Hello all, I have no real experience with dvd ripping - can someone tell me if its possible to rip only a section (like 2mins) from a dvd or will i have to get the whole vob first? Thx.
You will likely have to rip at least the VOB that contains the segment of video you want. If you use DVD2AVI it is pretty easy to isolate a particular part of a VOB sequence for output. Apparently the latest version of TMPGEnc can directly read VOB files now, but I haven't tried that feature. TMPGEnc also allows you to select a source range of the video for output.
HUN-YA!
Akai Rounin
Sync/align one short clip into one big clip
By diamondback in forum AudioReplies: 1Last Post: 2nd Nov 2011, 10:31 -
adding clip to DVD
By pcb in forum Authoring (DVD)Replies: 2Last Post: 26th Apr 2010, 16:00 -
Ripping my audio from my movie clip?
By superJT in forum AudioReplies: 3Last Post: 12th Sep 2008, 12:05 -
Transition from Clip to Clip in Premier
By Namrepus221 in forum EditingReplies: 2Last Post: 1st May 2008, 17:29 -
Do I need to stop clip analysis in order to export clip for dvd
By maevek1 in forum MacReplies: 0Last Post: 9th Apr 2008, 09:26
