can vcd or xvcd handle an audio sampling rate of 48000Hz, or does it have to be 44100Hz?
I haven't had any success at the higher resolution, so I guess I have to convert it down.
Anyone have any ideas on the best way to convert this down?
Cheers
Buzzrick
use virutal dub
load avi
select audio menu
conversion -> 44.1 16 bit stereo
compression -> PCM (wav)
select full processing mode
save wav (file menu)
done.
An app that views audio's frequency (Hz)?
By firebo14 in forum Newbie / General discussionsReplies: 3Last Post: 4th Jan 2012, 19:34 -
Audio Sampling Rate Info Wrong - DV-AVI Capture
By newtotheworld in forum Capturing and VCRReplies: 3Last Post: 21st Nov 2011, 22:18 -
Pinnacle Studios 11 - Low Frequency Audio Hum
By notheldge in forum Capturing and VCRReplies: 9Last Post: 15th Aug 2008, 12:07 -
Issues with sampling/audio sampling/data rates and VdubMod
By Suprman37 in forum Video ConversionReplies: 4Last Post: 22nd Feb 2008, 01:09 -
how to rip audio from DVD and AVI without re-sampling
By ted demen in forum AudioReplies: 9Last Post: 23rd May 2007, 10:23
