Hello there
It's my first foray into the world of VCD's and I'm having problems.
Using Sefy's Ultimate Newbie DVD Conversion Guide v2.0, I've just used the DVD2AVI to create my wav file. The file has been created but does not have the typical wav file icon, and when I go to the next stage of the process using the TMPGEnc - Wizard, it cannot find the file (?)
Any ideas?......please!![]()
Are you sure it created a WAV file ? in some DVD's it might create an MPG file, I suggest you find an Audio Track that is AC3, then it will surely create the appropriate file from it.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Did you have audio>Dolby Digital> *decode* ticked? Sounds like you might have had *demux* ticked.
You need to view file extensionsOriginally Posted by andyrh68
Double click Drive C to open a Window.
View > Folder options > View > Show all
Also remove check in "Hide file extensions for known file types"
Once you can see the file extensions, you will see the type of file it has made.
TMPGEnc will open other file type extensions, click browse and change the drop down arrow to "All" this will show all files on your hard drive (Including files it does not support) -
And then he'll probably realise he has demuxed rather than decoded. A lack of a further response strongly suggests it. 8)Originally Posted by KingJohn
Na, its probably a VOB file still, forgot to include the AC3 or MP3 in the conversion
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
need help to play wav file
By adom in forum AudioReplies: 4Last Post: 7th Aug 2011, 11:47 -
how to cut a wav file precisely?
By Lastman369 in forum AudioReplies: 14Last Post: 6th Apr 2010, 23:21 -
pops or clicks in wav file
By johnsees in forum AudioReplies: 7Last Post: 30th Jan 2008, 05:08 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08
