    Hi
    I've created a 60 minute XVCD file using TMPGEnc. Its MPEG-1 352x240 23.976fps CBR 1600kbps, Layer-2 44100Hz 128kbps.
    Nero goes mad and tells me its the wrong form and is an invalid MPEg stream for [S]VCD. The things is though that nero refuses to allow me to treat this as Mode 2/XA and hence it doesn't fit on my 80 Minute CDR. Can anyone help?
    This kind of thing has always worked in the past.
    -Darren
  2. Since it doesn't have the correct vcd headers nero wont accept it. You'll have to go into TMPGEnc.File> mpeg tools>simple multiplex>then put in the file and at the top change it to MPEG1 Video-CD. And then multiplex the file. It will prolly give you an error message, but ignore that, it'll work fine. Then burn and enjoy
    I will not eat oysters. I want my food dead - not sick, not wounded - dead.- Woody Allen
    fonoop.com
