  1. Need some help guys. Sometime when I try to rip the audio track from a divx file to a WAV, it crashes when it's almost complete. This doesn't happen to all the divx files, just some of them. I'm currently using WinXP with divx3.11, divx4 and divx5 codecs install. The way how I rip it is as follows.
    1)open divx file
    2)change to full processing mode under audio
    3)No compression or conversion under audio
    4)save as WAV
    Thanks.
  2. Have you tried with dbPowerAmp?
    http://www.dbpoweramp.com/
  3. I have found when that if you decompress the divx file first it will work fine.
  4. thanks for the advice guys. Anyhow, I thought what I was doing was already decompressing the audio part of the divx file to wav
  5. did you mean to decompress both the audio and the video of the divx file first?
