bought scooby doo copy, player logix 3000,it will play the second disc but would not play the first one. i tried copying the first disc again on clone same thing happens,tried with nero went to 70% then failed but would play,so there must be a problem with one of the sub folders please could someone help me with this topic. the copy i have is svcd format and errors at 70% so cannot copy cause of failiure
I have a similar problem. same film fuuny as it may seem. disk one is fine but disk two skips goes block and then eventually freezes. have tried to run it through mpeg corrector etc but no joy. if you get an answer please email me.
ok, ill let you know, ive tried saving the aveq file to hard drive so i could reburn to disk but gets to error, fails, tried from disk fails at error but will play alright up to error, tried multiplexing fails at error but will play, my old dvd would play the film alright , so theres something in one of the svcd files my new player does not like, but plays second disk great, and with clone cant change folders because it does 1 2 1 going to re-encode then burn see what happens but cant get new copy till next week and im desperate
Sounds like a damaged/corrupt CD-R disc. I had similar problems with copies of Spiderman & SW2 that a mate leant me. Wouldn't copy in Windows at all. Eventually got most of the MPEG file out with VCDGear but it ended up as garbage. Had to get another CD copy in the end.
how do i go abouit getting the aveq file form the disk to HD. tried to cut and copy and it would not do it. shame we cant swap somehow
just right click, send to my docs if theres errors probably wont work but try, problem with films end of your disk may be different to mine, mine stops when scooby hides under table after seeing creature in window
my supplier seems to think that it was burnt to fast but i acnt see that. disk one is perfect and VHS quality
