i have a problem
when i encode with dvdx i get the warning:
the output and input are not equal
pull down(up) will be performed
if i ignore the message and go on with encode the sound is very bad
is there someone who can tell me what to do
thnx in advance
greetings belo
Just tried it to see what happens, got the warning, but after that it worked just fine.
Do you have the audio on TooLame ? For AVI, and for Mpeg did you click the check Standard ? -
I use divx and on the input settings use output frame rate as 23.976(NTSC) on the input check mark pulldown 3:2 this will fix the error. I haven't had any problems converting either way but at least it gets rid of the error
progressive input gives interlaced output...
By bennn in forum ffmpegX general discussionReplies: 4Last Post: 9th Dec 2010, 13:32 -
DVI PC output to HDMI HD TV input?
By eros in forum DVB / IPTVReplies: 1Last Post: 26th Sep 2010, 02:38 -
RF output to DVI/HDMI Input
By torrentkid in forum Capturing and VCRReplies: 4Last Post: 19th Jun 2010, 03:41 -
To coax output devices, only 1 input on TV, solution?
By Rudyard in forum Newbie / General discussionsReplies: 3Last Post: 4th Aug 2009, 02:22 -
spdif output hack to input?
By tsantsa in forum ComputerReplies: 4Last Post: 31st Oct 2008, 01:59
