My Lasonic portable DVD player has connectors that I plugged into the front of my VCR that then plays to my TV (only one set of connectors on the back of the TV)
Does anyone think this could affect the performance of the DVD player? I know they have some stuff to keep you from recording to a VCR (which it seems I could do) so was wondering if any of the DVD problems I'm having are connected to that?
Thanks,
Those diagonal lines and pulsating red screen is called macrovision.Either
hack your dvd player or get a video stabilizer.
You could also hit up the local Radio Shack for either a Audio/Video A-B switch to share the connection on the back of the TV, or an RF modulator that will let you connect the DVD player to your antenna input and play on either channel 3 or 4. Personally, I'd go with the A-B switch it's cheaper and your AV quality will probably be better.Originally Posted by KayAt
Lloyd
Connecting DVD player through HDMI: 2 Problems
By Markaveli in forum DVD & Blu-ray PlayersReplies: 10Last Post: 22nd Aug 2008, 07:40 -
Connecting a Dutch LG DVD recorder to a American TV??
By Anna needs help in forum DVD & Blu-ray RecordersReplies: 6Last Post: 15th Aug 2008, 22:01 -
Connecting DVD player to a PC
By ppao in forum Newbie / General discussionsReplies: 1Last Post: 22nd Mar 2008, 21:09 -
Connecting a PVR to a DVD-R
By Sean08 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 8th Jan 2008, 14:53 -
connecting laptop to PC and using both DVD drives
By debrag in forum Media Center PC / MediaCentersReplies: 3Last Post: 4th Oct 2007, 12:20
