First of all I'll just like to say that I've been dealing with this problem for a while. I was following the first guide to making a VCD from a DVD. I used Smart Ripper, DVD2AVI, TMP, Chapter X Tractor and VCDEasy. I've done everything according to plan but when I try and encode the D2V file to an MPEG in TMPGEnc my system stops responding. Is there something that I'm doing that's causing this? I'm wondering if my CPU is just getting hot but there was an instance when I did get to encode the file but it resulted in two 5 MB files. If someone can assist me that would be greatly appreciated or just point me in the right direction. if you need any information from me please ask. thanks.
I have the same problem when the room temperature reaches 90 degrees and running TMPGEnc. I monitered the cpu temp and as it approches 115 degrees the computer freezes.
TMPEGnc work fine on cooler days.
Chas -
im having the same problem, even to the point where ive took the pc case off and had a desktop fan blowing into it, but still no joy. it crashes
any one have any ideas?
h264 encoding does not use all system resources
By sharkbite in forum Video ConversionReplies: 3Last Post: 28th Feb 2012, 19:16 -
BD Rebuilder hangs and shuts down system
By Mark AL in forum Blu-ray RippingReplies: 3Last Post: 7th Feb 2011, 08:43 -
Software Encoding on High-End System
By tbradyjd in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2010, 21:36 -
Looking to Build a Dedicated Encoding System
By Scarpad in forum Newbie / General discussionsReplies: 0Last Post: 9th Dec 2009, 13:10 -
Cutting video to several parts without encoding (on Unix system)
By Doctor_X3 in forum EditingReplies: 0Last Post: 23rd Feb 2008, 14:23
