When I'm converting avis to mpegs, TMPGEnc gives me a message not to make the mpeg larger than 4 GB because some authoring software won't be able to read it. That would waste some space on a 4.7 GB DVD. I'm using Ulead DVD Movie Factory to make my DVDs. Is there any reason I should stay below 4 GB?
Ed B.
Only reason I can think of is if you are using FAT32 filing system. If using NTFS on win2k/XP you should be able to create any size file you want. I do and have no problems with files over 4GB!
Hi,
I'm just getting started in DVD myself; but I think your're correct. Some softare won't support large AVIs and MPEGs. 2GB is the most common limit I've seen. The previous post about Win9x-ME and FAT32 is also correct; it has a 4GB filesize limit (2GB is you want to use Ms tools such as Windows Explorer to move files from one HD to another.)
Also, I understand from my reading from many sources that many DVD players won't read large VOBs (MPEGs authored onto DVDs). The most common size here seems to be 1GB. However, I have burned a DVD+RW with a 1.2GB file and it played in my Pioneer 343 OK.
Please post your results so we can all learn more,
Allan
Getting larger files than expected using Xvid to compress AVI
By pronco in forum Capturing and VCRReplies: 50Last Post: 7th Sep 2011, 10:42 -
Files larger than 2GB in Sony Vegas pro 8.0c
By Jacobus Serpenti in forum EditingReplies: 7Last Post: 9th Aug 2009, 09:24 -
can someone explain why extracted files are larger?
By mickthetree in forum Newbie / General discussionsReplies: 7Last Post: 8th Dec 2008, 22:28 -
Is it possible to encode divx files to larger than 5gb?
By yoda313 in forum Video ConversionReplies: 18Last Post: 4th Jul 2008, 11:25 -
Rendering should yeild smaller, not larger files right?
By InFlames814 in forum EditingReplies: 9Last Post: 4th Dec 2007, 22:21
