    Apr 2002
    Since there is more than one way to frameserve, could someone recommend the best way to frameserve. My source will be from both analog and DV camcorder. Could you give your critique of the first link shown below?
    I'm leaning toward Virtualdub. Although not frameserver dependent the codec I plan to use with Virtualdub will be PicVideo MJPEGcodec as described in second post. BTW, can this codec be used with dvd2avi or Avisynth?
    "How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)"
    http://forum.vcdhelp.com/viewtopic.php?t=87270&highlight=cce
    "High Quality Capturing with Little Frame Loss in VirtualDub"
    http://forum.vcdhelp.com/userguides/89899.php
    Apr 2002
    Is the following guide the best guide to follow for frameserving using Virtualdub and CCE?
    "How to convert to SVCD the FOOLPROOF way with Cinema Craft Encoder, including how to resize" http://www.vcdhelp.com/avitovcdfoolproofusingcce/
