I'm thinking of trying PowerVCR, primarily so I can edit the commercials from MPEG2 files, but I don't want to screw up my ATI install in any way. I know I can buy the MPEG2 plugins for other apps like TMPGEnc but if I'm going to shell out $$$ I thought maybe PowerVCR might be worth a try.
Also, does PowerVCR have to re-encode after an edit or is it a quick dump to a new file?
Thanks for any advice,
Jim
I'm capturing with an ATI TV Wonder Card and PowerVCR II. PowerVCR does not re-encode when you edit, but it DOES have some editing issues for some users.
I will say that my MPEG-2 captures with PowerVCR look much better than the ones I was doing with ATI MMC. The only problem I've run into with MMC after installing PowerVCR is right after I record something with PowerVCR MMC won't open until I restart. But once I started using PowerVCR I stopped using MMC at all, so that's not really a problem for me.
Here is a terrific link about what to consider when thinking about buying PowerVCR:
http://forum.vcdhelp.com/viewtopic.php?t=88306
And here are some links detailing some of the problems some users have had with PowerVCR:
http://forum.vcdhelp.com/viewtopic.php?t=93475
http://forum.vcdhelp.com/viewtopic.php?t=98622
Also, before you buy, you might want to check ebay or some auction site like that. I bought my copy of PowerVCR II directly from the Cyberlink site and payed $50 - - but on Ebay users are selling the same versions for as low as $14.
Hope this was some help! Good luck in your search!
-Jerzybo -
Thanks, Jerzybo. I've been eyeing the ones on ebay already, just making sure about the program before I buy it (even if it is only $15).
jim
Videosoap in ATI MMC. Couple of questions
By andrewjameshoward in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 13:49 -
Anybody know how to get ATI MMC version 9.02???
By pukhog3 in forum Capturing and VCRReplies: 10Last Post: 10th Sep 2009, 18:12 -
How to use ATi MMC Multimedia Center TV
By c627627 in forum User guidesReplies: 2Last Post: 8th Apr 2009, 04:14 -
More ATI MMC questions. (I RTFM'd.)
By palouse in forum Capturing and VCRReplies: 5Last Post: 13th Jun 2007, 21:08 -
where to download old ATI MMC?
By mencius in forum Capturing and VCRReplies: 2Last Post: 23rd May 2007, 00:44
