  1. I got some cool animations in .swf format and want put them on VCD i have managed to convert the animation to mpeg 1 but i cant convert the audio. Does any one know how?
    May 2002
    Brazil
    have you tried to save it in *.mov?
    The TMPGEncode suports Quicktime Movies using a add-on(plugin).
    go see in : http://www.vcdhelp.com/tmpgenc.htm
    I made this one time...
    Dudulho
  3. The sound is there when ive saved it as *.mov file but when i encode it using tmpgenc i have no sound just video.
    May 2002
    Brazil
    hey unlucky!
    found something that may help you!
    a program that can extract the audio stream from a SWF file and save it as MP3.
    The program is SWF Browser and the address to the site is:http://www.swifftools.com/stools/
    it's version is 2.93 and the size of the file is 1.3mb.
    hope helped you.
    Cya!
