I have been using Tmpegenc. it has worked for sometime. But recently i have tried converting video files from avi-mpeg. It starts off encoding and then stops at a frame rate of 33/.......
I was wondering if anybody is having the problem. And is there a solution to this. Any other useful software that i could possibly choose.
Thanks[/b]
Have you checked your AVI file for errors using V.dub?
What about changing your VFAPI settings priority level in tmpgenc
under option>environmental setting>VFAPI plug in?
ALL Codec's installed? Have you re-installed them?
Have you tried spliting the audio into a wav and using
that as the audio source?
Maybe d/l a whole new copy of tmpgenc and the VFAPI handler
in case it is corrupted?
Is your avi d/loaded from the net? If so have you tried to
frameserve it from V.Dub?
phew.. -
THANKS MATE,
I DID WHAT U SAID ABOUT SAVING THE AUDIO AS WAV USING VIRTUAL DUB. I THEN TRIED IT,WORKS FINE,
THANKS ONCE AGAIN
DVD Architect Pro 5.2 error writing file?
By dabezt in forum Authoring (Blu-ray)Replies: 7Last Post: 30th Aug 2011, 07:55 -
ShowBiz DVD 2 Error - Failure writing the disc
By smbcingu in forum Authoring (DVD)Replies: 4Last Post: 2nd Jan 2011, 16:34 -
Error in writing a YUV frame
By krao in forum Newbie / General discussionsReplies: 11Last Post: 1st Sep 2009, 10:47 -
DVD writing error
By nathy85 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Nov 2007, 17:00 -
Error writing to media
By minepup in forum DVD & Blu-ray WritersReplies: 2Last Post: 21st Jul 2007, 07:28
