I made a VCD using Nero 5.5 on cdRW and now that I finished watching it, I can't erase it. I tried quick erase and full erase.
I don't want to waste my RWs if I can't delete it anyway I might as well use a R disk instead.
I have the same problem, could it be that the Finalize cd checkmark is already greyed in when I go to make my cds's on cdrw's? If this is the problem how do I change it?
The 'finalize cd' just means it closes the recording session. It will not effect the ability to erase a CDRW.
Do you get an error message? -
I've had that problem with Nero too. I'm not sure what causes it but odds are your CD-RW is fine. Try erasing it with DirectCD or CDRWin, works like a charm.
I don't really know what I did. All I know that I did do, was defragment my hard drive, and shut off most of my running programs. I then ran Nero, and erased the Cdrw successfully!? Direct cd is not even installed on my system, so I know it can't be the problem. Weird..
nero is just plain fubar on erasing cdrw's IMO. Remember the early release you couldn't even do a quick erase.
Michael
AVI on CDRW stops playing in DVD player?
By leonk in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2012, 22:53 -
CDRW Erasing Cancelled - CDRW NOT WORKing
By Sarao in forum ComputerReplies: 6Last Post: 5th Feb 2010, 11:55 -
Question how to delete files that won't delete
By jimdagys in forum ComputerReplies: 18Last Post: 9th Sep 2009, 14:09 -
Problem playing DVD-R in several CDRW/DVD
By shortytigg in forum Authoring (DVD)Replies: 7Last Post: 20th Feb 2009, 14:39
