hello!
i have a sony digital camera and a conceptronics firewire card!
the problem is that i capture the video to hdd with ulead video studio 6 in dv format,until here everithing fine but then i encode with tmpeg(the last) and i set to high quality dvd (to burn on dvd+rw)and i burn with sonic my dvd,everything ok,the problem is that the image only plays good on power dvd because when i put it on my dvd (yukai)and in a 51cm sony tv the image when is in motion shows a lot of pixels!what do you think is the problem !is it the software or my defenitions??
below are my computer specs if you think that something needs to be changeng inclusive the software pelase let me know!!
thanks a lot!!
my pc is:
amd thunderbird 1200mhz
board soltek with 512 sdram
hdd seagte ata 66 40gb(wouldnt it supose to be ata 100??)
geforce 2 ti 32mb ddr
atx 300 watts
hp dvd writter 100i
tmpeg(latest on the page)![]()
I have a sony pc120 and have the same prob m8 if anyone knows where the prob is coming from I would like to know also
Also do you get alot of interlace on the screen??
Appropriate pixels?
By bsuska in forum Authoring (Blu-ray)Replies: 52Last Post: 20th Oct 2010, 09:33 -
how do I convert a video that shows square pixels to no pixels?
By sxpredman in forum Newbie / General discussionsReplies: 4Last Post: 10th Jan 2010, 03:56 -
Another question: Converting square pixels into round pixels.
By Earthling2000 in forum Newbie / General discussionsReplies: 13Last Post: 23rd Nov 2009, 11:20 -
should use square pixels or not for 16:9?
By j.man in forum Video ConversionReplies: 5Last Post: 4th Mar 2008, 22:28 -
1.8inch is how many pixels?
By Shaorin in forum Newbie / General discussionsReplies: 6Last Post: 16th Jul 2007, 20:23
