whenever i tried to apply a transition in adobe premiere 6.0, it has absoloutely no effect on the videos whatsoever, i have the videos in video1 a and b, with the transition in the overlapping region in the transition bar, still nothing..i assume its very esy, so maybe im missing something simple.....any suggestions?
thanks
You must reneder the area before you can see the transition.
How to add transition:
http://forum.vcdhelp.com/userguides/92223.php#video -
Right click on the "transition clip"(the one between Video 1 a and b) and bring up the transition dialog. The slider on your left frame [that is marked A] should be in its start position. It may have happened that you moved the slider to the end position and left it there while verifying the transition settings.
what transitions to use and when ?
By codemaster in forum EditingReplies: 12Last Post: 22nd Mar 2011, 14:03 -
My transitions keep bugging out.
By Joeytwo in forum Newbie / General discussionsReplies: 0Last Post: 19th Feb 2011, 03:58 -
looking for transitions like in this video
By Twio X in forum Newbie / General discussionsReplies: 8Last Post: 9th Dec 2009, 04:02 -
GFD - transitions between menus
By dani96 in forum Authoring (DVD)Replies: 0Last Post: 24th Jul 2008, 06:23 -
how can i make transitions
By wan2no in forum Authoring (DVD)Replies: 3Last Post: 14th Jun 2008, 18:33
