Hi,
I am new to this game but want to get the best.
I want to transfer my films onto DVD. I have a Sony DCR PC115E (PAL vesrion), which came with the MGI 4 software. I can capture my films onto my P4 2.4Ghz in no time through my firewire card. This works great. Like many other people, the resulting AVI video on my flat panel does not look great but it probably comes from the progressive rather than interlaced feature of the screen. It got me worried first. The editing function is working OK. The scene detection worked fine. I even managed to mix some audio (by the way, MGI is great to capturing audio CDs when no other software handy). I managed to convert to MPEG-2 as I eventually want to burn it onto DVD-R to read on my Malata N996. I intend to go for the Pioneer A04. The conversion process is fairly fast: approximately 15 minutes of conversion for 5 minutes of film. I am working in PAL through the whole process since my player can play it on my NTSC TV. The result played onto my computer with power DVD does not look great: picture are not fine/clear quality as I would expect for 530 horizontal lines of definition on the camcorder.
Questions:
1. Will the be the same once I have burnt it on a DVD to play on my standalone player ?
2. is MGI as bad as what I have read on other forums and what software would you suggest for capturing, editing, converting and eventually burning.
3. Any other useful tips / suggestions ?
Thanks.
Results 1 to 1 of 1
Help! screen capture and editing advice for a volunteer
By kalu523 in forum EditingReplies: 10Last Post: 20th Jul 2010, 11:29 -
Need advice with PC build for video editing.
By bweath in forum ComputerReplies: 32Last Post: 29th May 2010, 20:04 -
General Video Editing Advice
By DrLazer in forum EditingReplies: 2Last Post: 13th May 2010, 12:32 -
New here, Capture + editing + encoding + burning.
By Sikander in forum Video ConversionReplies: 5Last Post: 6th Nov 2007, 14:22 -
Capture and burning advice needed
By ccm in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 12:25
