i have one problem after burning the vcd.After i burning the vcd their are only several file can be watch other file are only not playable file(i have test both between vcd player and pc) .For your knowledge i have use nero burning rom.I have drag and drop .mpeg that i downloaded from kazaa.SO doing a drag and drop file much be a easy thing.Can i know .?cant i know why my vcd doesnt success..i have to use about 13 file dropped of consert movies in the 1 vcd and they should have about different types of mpeg especially pal and ntsc and different frame rate.Can i know how to solve my problem?
VCD to VCD back-up
By fiiido in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th May 2011, 12:39 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
