which file on a dvd are the actual subtitles?
i thought it was the .spc files, but those don't seem to work.
help me!
which program are you using to examine the VOBS and extract the subs?
The subtitles on DVDs are multiplexed into the VOBs, not stored seperately... you need a sub ripper to extract them.
I use SUBRIP, personally. The OCR is a bit grumpy, IMNSHO, but it gets the job done.
This program can export either the subtitle BMPs or dump the OCR data to various text script formats such as MICRODVD, SUBSTATION ALPHA, and my old fave for sutitling, circa around 1990 originaly, JACOSUB for the Commodore Amiga (!) .
Dumping to script is my personal preferred means, since I inline the subs later using SSA's VIRTUALDUB plug. -
right now i'm using dvd extractor or yade to extract the movies files. will those work or do i need something else?
where do i get the software that you speak of?
i have some anime and foriegn films i would really like the subtitles for.
thanx
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 08:22 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 17:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 09:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 16:28 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 17:10
