Downloaded a movie and can't get it to play any ideas plz.
Says its an Unknown Format and Nero's having none of it either,if i click on preview i get the message"Video not available,cannot find 'Vids:divx' decompressor.
Any help here please,probably a minor thing but it's new to me
Thanks![]()
Results 1 to 10 of 10
The codec needed to play the movie... Is not installed on your computer. Go dashing off and download the Nimo codec pack, it has everything you need... Well almost, it dont have DivX 5 codec
Nimo
http://nimo.everwicked.com/ http://perso.wanadoo.fr/nimo/
DivX 5 (If you need it)
http://www.divx.com/ -
i think he needs the divx codec, the "vids:divx" for example is the missing codec. i got the same message once but mine was "vids:mp43". never could find a codec to get it to work...
Thx for the answers but what exactly am i supposed to do,bearing in mind i'm a newbie and thick to boot
Vids:divx = DivX 5 www.divx.comOriginally Posted by fyreboltx2
Vids:mp43 = M$ MPEG-4 V3 (Nimo) or mpg4c32.dll (Mpeg4 Codec.exe)
Both available from Kazaa
Download and install the Nimo codec pack, then your AVI will play just fine. You can then edit it later if you wish.Originally Posted by OdditySins
http://nimo.everwicked.com/ http://perso.wanadoo.fr/nimo/ -
Sorry to be a pain but i downloaded the Nimo codec pack and it still wont play.How comes the AVI file says it runs for 61 minutes 27 seconds yet it's only a 139MB in size.I reckon its duff but as i said i really have'nt got a clue here so if anyone can point me in the right direction before i delete it i would be grateful
Thx again for all your help.
GuestI downloaded an avi that was 98 minutes and 197 meg, turns out it wasOriginally Posted by OdditySins
an asf file in disquise. Boy, was I surprised. BUT, your problem sounds
like a codec for Divx due to the message your received.
Did you double click on the Nimo.exe file? This should install the codecs.
Not sure but you may have to reboot after this.
Goodluck. -
try downloading the latest divx codec (version 5)
and it depends on the bitrate... tell you the truth, u can fit 100 hours in just 100MB but its gonna look like crap! a higher file size with a low running time means better quality. or higher bitrate = a better video.
hope im not confusing you. if i did then contact me on AIM, ill try to help you.
If it says "'Vids:divx' decompressor" this is the DivX 5 at www.divx.com or download the pro with a keypenOriginally Posted by OdditySins
from Kazaa
There are a few times when you need the fake codec (For the fake movies)
Advertisement
Better to use Sig2dat and download verified movies from Kazza
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 10:32 -
Small prob with DVD Flick
By Tool Man in forum Authoring (DVD)Replies: 2Last Post: 27th Dec 2007, 07:29 -
Window doing full and and small screen[maximizing auto] prob
By vipertongn in forum ComputerReplies: 1Last Post: 12th Sep 2007, 02:06 -
gc prob
By Mr anderson in forum ComputerReplies: 6Last Post: 10th Sep 2007, 06:33 -
MPEG DV prob
By mainegate in forum ffmpegX general discussionReplies: 0Last Post: 24th Aug 2007, 18:01
