This is a pretty odd question but maybe someone will be able to help me. I had a bunch (5,000+) of .jpgs. I made a VCD using nero, its like a picture slideshow. Then, stupidly, I deleted all of the images off of my hard-drive. I was wondering if I could convert the vcd back to .jpg's? Thanks!
Results 1 to 25 of 25
Ok, I have the CD in the CD-Rom, in VirtualDub what file do I select?
I have files in 5 folders.
[Cdi]
[Ext]
[Mpegav]
[Segment]
[Vcd] -
Um... Did you open up the folders to see if there was anything in them
your looking for the .dat file MPEGAV > Avseq01.dat ?
I did that but it only recorded 1 image and a fraction of another. What did I do wrong?
So you loaded the .dat file into Vdub, could you preview it OK ?. I did test this before I posted on a shrek VCD and stopped it after a few seconds with hundreds of images saved.
It showed 1 image and a fraction of another when I previewed it. Remember this is a Image VCD, nero lets you do this.
When I said preview, you just press the play button to view the movie, it will display all the pictures.Originally Posted by kenetik
Is the .dat file, one large file, or do you have sevral .dat files ? I'm thinking about menu's etc. What size is this .dat file ?
You suppose to have loaded it into Vdub and press play to preview, why are you using Nero ?Image VCD, nero lets you do this -
In MPEGAV the "AVSEQ01.dat" is 639kb and that is the only .dat in that directory. But when I go to the directory "SEGMENT" there are 852 .dat files all being Item0001.dat, Item0002.dat, and so on.
did you load the AVSEQ01.dat into Vdub and press play ?
Have you loaded any of the other .dat files into Vdub ? -
did you load the AVSEQ01.dat into Vdub and press play ?By "preview" I mean, hitting the play button.. Exactly like you said.It showed 1 image and a fraction of another when I previewed it.
Hey,
I also have a jpg vcd created with nero, I tried to extract the jpgs from it with no luck-- the aveseq01.dat file doesn't have the jpg info- the jpegs are in each of the segment files (item0*.dat)- you can load those segment files into vdub and you'll see the bottom of the jpeg is missing or greened out??
this has me cornfused also
Have you attempted to convert those DAT files to mpg?
(see the "how to" convert link over on the left)As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Well I thought about your post as you said there were "852" .dat files but your original post said there were "5,000" jpg's so it did not sound right.Originally Posted by kenetik
If you load the .dat files into TMPGENc what can you see when you preview ? and why would the large .dat file only have 1 image, what comes after it ? a blank screen ?
Does the VCD play ok on your computer ? -
I guess only 852 images is right, but I give up..
I'll just watch these images on the RCA
Thanks for the help.
Im sorry I gave up so early, it's just that I have a lot of business to take care of and I can't just pussy foot around! -
oh man! I was really hoping to find out if this could be done
I tried to load the AVSEQ01.DAT file into VDub but I got this error- Error reading "E:\mpegav\avseq01.dat": incorrect function
I also tried converting the avseq01.dat file to mpeg- it didn't work.
I converted a few of the ITEM0x.DAT files to mpeg but they were all messed up when I previewed them in vdub.
I created this jpeg "slideshow" disc with Nero 5.5.7x, there is one AVSEQ01.DAT file-> 635,084b and there's 1,425 ITEM0x.DAT files each exactly 352,844b
none of the files could be previewed in TMPGenc either. -
Ok I just made a quick disk with 5 images on it, the first image is displayed then movies on to a slide show containing 4 images.
Now I load Vdub and load in the Avseq01.dat inside MPEGAV this contains none of my images or slide show, instead I see a warning screen telling me my DVD should support this type of disk
I look inside the SEGMENT folder and can see 2 files, I load "Item0001.dat" and can see this is my first images before the slide show. I load in the second "Item0002.dat" and can now see my slide show with the remaining images.
Depending on how this disk was made, this is going vary -
Any ideas? It's pretty frustrating not being able to get these images, they are pretty important..
Have you loaded the other .dat files like I did ?Originally Posted by kenetik
Its basically the original images chopped up in quaters, and some of them are the full images but not all of them..
I guess if they were all together as 1 mpeg, it would work, Must have been the way Nero made them. Can you email one or 2 of them ?
I know next to nothing but by any chance if your machine is always on check your recycle bin. I have no other help sorry.
Playing JPEGS on a DVD player......Help
By efiste2 in forum Newbie / General discussionsReplies: 4Last Post: 18th Nov 2010, 16:43 -
JPegs won't play on TV
By didikai in forum Newbie / General discussionsReplies: 2Last Post: 11th Jan 2009, 17:04 -
Crop/Center jpegs for timelapse?
By tjubb in forum EditingReplies: 1Last Post: 14th Sep 2007, 21:39 -
Import JPEGS to Premiere
By videobread in forum EditingReplies: 1Last Post: 26th Aug 2007, 15:11 -
extracting jpegs from vcds
By pk475 in forum Authoring (VCD/SVCD)Replies: 2Last Post: 9th Aug 2007, 10:38
