hi boys I try to convert avi movie to mpeg movie but whrt the conversion is in 94% a window appears and says this:
"Illegal floating decimal point calculation order"
and not finish encode.
can I do something ????
thanxs and please help me
darkzero
hey hi again
whats up here, no body knows what is the answer of my question???
please helpp mee }}
darkzero -
is quite a common problem but can be sorted quite easily.the file will be saved on your hard drive up to where the problem occured,simply open it and see how far in time it has gotto,then load the full file back into tmpgenc and use the "source range" to fast forward the video to where just before the problem occured(use the slow forward arrow) and when it hits the spot where the problem occured it will tell you that there is the floating decimal point order,click ok then use the slow forward button again until the video has no more problems and set your start point from there,rest of the video will then be decoded for you and then use merge and cut to join the two pieces together . you must take the last couple of frames off the first part of the video before you can join them using merge and cut other wise it wont join properly because the illegal floating decimal point is still there. hope that explains it for you
Like Tommyknocker said...read the guide.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Replacement for TMPEGnc DVD Author for the Mac?
By The Monkees in forum MacReplies: 1Last Post: 24th Feb 2009, 13:36 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
AVI File Not Supported by TMPEGnc?
By The Monkees in forum Video ConversionReplies: 5Last Post: 3rd Feb 2008, 18:26 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
