i'm trying to convert gone in 60 seconds from .avi to .mpeg, i converted the first hour no problem but once i get to 67% on the second hour i get that same error, illegal floating decimal point calculation error, now it's happened 3 times, what can i do?
I will ASSume this is a DivX AVI. Have you verified all the Audio and Video is okay in the video through a viewer program? Check that out to make sure everything is okay. If this is a DivX encoded AVI you may want to try running DiVFix on the file just in case any errors introduced during download are fixed (may not work but worth a shot).
Now try encoding to MPEG again.
Before converting to MPEG you may want to try creating a new, uncompressed AVI via Virtual Dub and using that as your source for MPEG encoding.
I hope that helps. -
Try the info here = http://screw.wz.cz/avidef/AVIDeFreezer%20Tutorial.htm & then get the program here = http://www.mnsi.net/~jschlic1/ I kept getting a decimal error In TMPGEnc I this program fixed it right up. You will also need VirtualDub to help out = but itz pretty straight forward!!
_________________
Test Your Anti Virus & FIREWALL at IGGYZ.COM
<font size=-1>[ This Message was edited by: IGGY on 2001-08-24 01:38:43 ]</font>
Help - invalid Floating point operation!!!!
By Pintocas in forum AudioReplies: 1Last Post: 15th Sep 2010, 10:28 -
r6002 floating point error with MPC , maybe
By BWMagus in forum Software PlayingReplies: 5Last Post: 19th Mar 2009, 09:08 -
MPC Runtime Error, 6002 floating point support not loaded.
By Leo99 in forum Software PlayingReplies: 5Last Post: 24th Nov 2008, 03:22 -
Illegal Disc error
By smackypete in forum Authoring (DVD)Replies: 10Last Post: 19th Jun 2008, 20:00 -
Illegal Disc Error
By ScottM808 in forum DVD & Blu-ray WritersReplies: 25Last Post: 12th Jul 2007, 15:51
