    Jul 2001
    Richmond, VA
    Is there a way to cut a movie while it in spruceup? I have a movie that I have just finished authoring and realized that I don't want the small 45 second trailer that comes after the credits. Is there a way to set it so that the movie stops playing at a set time?
    May 2001
    Sorry, start to finish.
    You'll have to cut the file outside of Spruceup.
    Jul 2001
    Richmond, VA
    Thanks, that is what I was afraid.
  4. not sure if this will work but you save your project as a title set or disc image (it's techincally the same) on your hard drive. Once it's done check the very last vob file (ex: vob_01_5.vob), and play this in windows media player(or where ever), if you are lucky their will be a chance that the last vob file might be just your trailer that you do not want, if so delete that vob. You would then have to fix the sectors in the ifo file for your film.
    You can do that by using ifoedit (tools section on here) by opening the ifo file (video_ts.ifo) and then hit the button on the bottom "get vts sectors" once done save the new ifo (using what name it provides in the save box) and you should be all set, test it out on your pc--
