Has anybody succesfully managed to simple multiplex this using TMPGEnc??
Everytime I try it gets to about 550MB of the file then stops. Without rewriting the headers.
The resulting file plays ok with the last part of the file missing![]()
I've had the same problem. Might be due to the Ligos splitter that's used in the mpeg file. Anyone have any ideas?? This is the only way for me to play SVCDs on a Sony NS400...
cd1 worked fine but i cant get 2 or 3 to work, tmpge wouldnt even accept the mpeg files extracted from the bin files so i downloaded the mpeg files separately, the multiplex gets halfway through and then stops?
yep same with me..
The only program I know to re-encode it is TMPENc but I don't really want to spend 6 hours re-encoding it to SVCD when it is a SVCD to start with -
I have just re-encoded the first two cd's and am half way through disc 3..
I use a program called pvastrumento2.0.14 to rewrite the mpeg file then use TMPFEnc to re-encode it as a SVCD then use the simple multiplex and they all work fine..
You can download pvastrumento2.0.14 from my site http://micks-tools.co.uk
Mac version of VLC is less functional than the Windows and Linux version
By HitTheRoad in forum MacReplies: 12Last Post: 30th Oct 2011, 03:48 -
Simple task, not so simple (rip/quicksync)
By Trife in forum Newbie / General discussionsReplies: 10Last Post: 12th Aug 2011, 19:57 -
SUPER version 39 is broken - reinstall older version?
By castalla in forum Video ConversionReplies: 7Last Post: 3rd Nov 2010, 18:20 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 22:38 -
where to download old version of dvd fab??? error in new version
By willhenderson in forum Newbie / General discussionsReplies: 1Last Post: 1st Dec 2007, 16:00
