This is kinda "on the fringe........"!
Does anybody know or have any information about the format of CDs that can be played on standalone MP3 CD players?
Do the files have to be in any particular directory structure? Do certain files have to be in any particular physical position on the CD (like with VCDs)?
Thanks for reading!
If your using nero to burn them.
Choose CDROM-ISO, then drag your files over, and burn.
If your running xp and are using the built in burning, just drag your mp3 files over, it will ask you if you want to burn them to play on your computer or on a cd player, choose the computer.
simple as pie -
tHATS pREETY dUM bECAUSE iF yOU wANT tO mAKE aN mP3 cD iT wOULD jUST hAVE tO bE a dATA cD. cONSISTED oF mP3'S bUT jUST mAKE sURE tHAT aLL tHE xTENSIONS aRE .mP3............. ImAgE0nE
EvErY0nEs A HaTeR BuT mEE! -
almost as dumb as idiots who need to keep changing the case of their type, you wouldnt know anyone like that would you suckonthis?
nAW i wOULDN'T kNOW aNYONE wHO dOES tHAT mR. bITCH! i lIKE the pINK bETWEEN yOUR tHIHGS!!Originally Posted by mrpinkEvErY0nEs A HaTeR BuT mEE!
You should also check with the instruction book for your player. Some players support different options like long/short file names. I have an MP3 deck in my car whick supports the old ID tags, but not the new ones. This can be important depending on what you want to play your MP3s in, especially older MP3 players that are more picky about how they are burned.
This is NOT a dumb question, in fact a LOT of people have trouble with this, as some players are wildly different from others as far as compatability. I believe these rules must apply:
1--> Make it a MODE 1 (data) CD.
2--> Create FOLDERS underneath the root, THEN drag-and-drop your mp3's to be UNDER those directories. Certain players (like Apex DVD's) require that they be in SUBDIRECTORIES. So long as they're at least 1 level under the "root", you can decide how to sort them from there. If you don't do this, it'll act unpredictably.
3--> MAKE SURE TO "CLOSE" THE DISC so no more sessions can be written. Lots of players will skip over some files if you don't do this, who knows why.
Note also if your player is a standalone DVD, and it only shows the first 8 characters, this isn't the fault of your burn, but just how the player reacts. Not much you can do about this.
If I said anything wrong, correct me...
Can I batch process some mp3's with Audacity to make them louder?
By snafubaby in forum AudioReplies: 2Last Post: 10th May 2011, 13:24 -
How to make dual mp3 tracks
By NotoriousGRK in forum AudioReplies: 3Last Post: 23rd Jan 2011, 19:21 -
How do I make video with one .JPG and MP3 file
By daka in forum LinuxReplies: 3Last Post: 11th Nov 2009, 13:19 -
Best/Easiest way to make multiple segments of a mp3 file?
By raydeneg in forum AudioReplies: 4Last Post: 7th Oct 2008, 08:47 -
looking for tutorial on how to make video for youtube using mp3 and images
By method in forum Newbie / General discussionsReplies: 3Last Post: 24th Jul 2007, 08:15
