Ok i found the star wars movie (456) and want to make them as a vcd or svcd(if I can find a freeware for it). I encode it already using tmpgenc format ntsc film but i notice the image skips every 5 seconds or so....
I know they are at 25 000 format (pal) but i'dlike them as ntsc cause i dont know how my tv or dvd will react to pal. I thought that i could just ask tmpgenc to convert it for me but obviously that led to my skipping problems...how can i solve that? do I need to burn as pal?
if they are 25 fps, then they are in pal format.Originally Posted by hola99
I would try encoding a small test clip as a pal (S)VCD and see whether it plays ok or not. on my pioneer, and old crappy TV, I have no problems playing PAL discs. if that doesn't work, I would search this forum for PAL to NTSC and that should find a good conversion methodwhat are you askin' me for...
I'm an idiot!
Topher Grace edited all the Star Wars prequels into a single movie
By Noahtuck in forum Off topicReplies: 1Last Post: 28th Mar 2012, 02:16 -
help with star wars saga br
By kn5150 in forum Blu-ray RippingReplies: 9Last Post: 21st Sep 2011, 17:55 -
What was your favorite star wars movie?
By johns0 in forum PollsReplies: 19Last Post: 3rd Jul 2011, 20:39 -
Edit Video Like in Star Wars ?
By SEJedi in forum EditingReplies: 15Last Post: 28th Apr 2011, 10:50 -
Star Wars 3D
By stiltman in forum Off topicReplies: 20Last Post: 26th Oct 2010, 20:11
