    Feb 2001
    swedois
    Hello
    I´ve got a leadtek winfast tv 2000 card and im using the latest drivers from http://btwincap.sourceforge.net/download.html.
    Most of my captures works flawless! 25fps with rgb24 or yuy2, about no dropped frames. Somehow though I can´t get rid of dropped frames if im doing more than 7 minute captures, I usually get 1 dropped frame after 7 minutes or so, how come this appear? It doesn´t matter if I capture at 176x144 or 480x576, so it can´t be the Harddrive or the CPU, cause the cpu load does not even reach 30% @ 176x144 with huffy. Anyway thats just a litte wondering, the reason i posted is because some VHS tapes i try to rip is totally impossible to capture !!??
    When i´m in preview mode the image is laggy and it looks very interlaced somehow, when i try to capture i get loooads of dropped frames. No matter if i set the fps to 15 it´s always 5 fps beneath the selected. Is it some kind of signal or copy protection??
    If so, is it possible to bypass this!?
    My system:
    Athlon 1400 @ 1600mhz
    Abit KG7
    IBM 60gxp 30gig
    WD 80 gig
    Winfast tv 2000
    ATI radeon 8500
    etc
  2. How old are the vhs tapes? I was having the same problem with my older home videos and was going mad trying to fix the problem. Then I got to reading all the posts about the same problem and found out it is the age of the tape that was giving the bad captures. After a while the tapes start to degrade and loose the strength of their signals and need a device such as a time base correct to help sort these weak signals out and make them more recognisable to the capture card. I finally received a tbc3000 and it has helped by about 100%. It has the feature of being able to adjust color tint bright and contrast plus re-syncing the vid and aud ,It has made the videos come out a lot cleaner looking on disc.
    ASUS p4c800
    1 gig ddr 400mhz ram,2.6 P4 800mhz fsb
    15gig,40gig ata100's
    pvr250 capture card
    Geforce4 128mbddr mx440 video card
    Datavision TBC3000 time base corrector
    creative live sound
    Sony U10A dvd-rw,sony crx-160e cd-rw
    windows XP
    persistance
  3. I may have a solution for you. This is my experience, I do not know if some one has already posted it before.
    I had the same problem with some old tapes as well as some new ones, which have scenes with lots of water or sand (I live in Middle East). I always capture at 480X576. But the bad tapes used to drop frames even if I set at 352X288 (PAL). I even tried some lower resolutions for testing purpose, but it still dropped frames. As you mentioned, it would drop frames like crazy, though the CPU usage was 30% or so.
    However, one day I decided to try all the resolutions available for my card (as listed in Virtualdub's 'custom format'). And I suddenly found that at 352X480, it didn't drop any frame at all. then I tested all my bad tapes at that resolution and it worked! So, I think, there may probabaly be one PROPER resolution for your card/PC configuration, which works with maximum efficiency.
    Hope this info helps you and others with similar problem.
    Feb 2001
    swedois
    How odd!!
    I tryed the 352x480 you recomended but it didn´t work, then i tryed the maximum resolution 720x576 and boom the picture stopped to lag?
    Im not sure it works 100% though, il be back for more info
  5. I tried the 352x480 and it works great, I only dropped 6 frames while last time i dropped 600 on the same capture
    Feb 2001
    swedois
    Alright, the lowest res i could reach without losing frames was 704x512.. If i go lower than that on two of the strange tapes things gets messed up, can anyone explain why you have to reach this resolution without dropping frames?
    Canada
    Hi,
    Just FF and REW the tapes a few times. This often reduces dropped frames.
    Allan
