I have a movie in bin format but without the cue file. i extracted the .dat file and used NERO to burn it to VCD. It loads it in the DVD player but when i watch it theres green blocks everywhere and the picture unwatchable! The sound is there tho. What am i doing wrong?
thanks for help
DOM
If you have a bin file without a cue file, then you can regenerate the CUE file by using VCDXRIP on the bin file and then immediately recombiling a new CUE/BIN with VCDXBUILD.
These two programs are part of the VCDImager package. VCDEasy is GUI to both if you don't want to use the command line:
http://www.vcdeasy.org
htto://www.vcdimager.org
Regards.Michael Tam
w: Morsels of Evidence -
hi thanks for the reply.
Should when rebuilding the file, should i choose normal bin/cue or bin/detailled cue? -
Unless you are using Fireburner, use "detailed".
Regards.Michael Tam
Help! Movie Is Unwatchable (interlace problem?)
By Aaron1927 in forum Video Streaming DownloadingReplies: 5Last Post: 2nd Jul 2011, 10:31 -
For AVG users (missing bin file)
By stiltman in forum ComputerReplies: 6Last Post: 17th Aug 2008, 23:16 -
Opening .bin file jpg
By chewie8008 in forum ComputerReplies: 4Last Post: 18th Jul 2007, 16:01 -
Bin file
By anton225 in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 13:05 -
how to burn a BIN File
By Chris 67 in forum Newbie / General discussionsReplies: 4Last Post: 28th May 2007, 07:44
