Results 1 to 9 of 9
  1. [** Problem Description **]
    When I burn on the system described below, the DVD's turn out only semi-readable.
    Meaning, some files (for example, VTS_03_1.VOB) are unreadable to any set top player or
    DVD-ROM drive. The DVD-R drive itself can read the disc perfectly.
    I tried making a clean Windows 98 Installation instead, and burned then, which worked
    perfectly - disc perfectly readable in all dvd-rom/set top players (Same image file, same burning program, same brand of media). so I reinstalled
    Windows XP, reinstalled all my software (as described below) and again, burning won't work.
    Any burning program reports 100% successfully completed, yet the files in question (always
    the same files) are unreadable.
    I even *replaced* my burner for a new one, but problem is still here.
    Known facts:
    A) Burner is OK
    B) Media is OK
    So what's causing the problem?
    [** SOftware installed according to 'Add/Remove Software' **]
    ACDSee
    Adobe Acrobat 5.0
    Audiogalaxy Sattelite
    Cool Edit 2000
    DAEMON Tools
    DivX Codec 3.1alpha release
    Download Accelerator Plus
    FlashFXP
    GEAR PRO "Professional Edition" 6.01
    Getright
    ICQ
    Intel(R) PRO Ethernet Adapter and Software
    LiveUpdate 1.6 (Symantec Corporation)
    Microsoft Office XP Professional with FrontPage
    mIRC
    Mjuice Compononets
    Nero - Burning Rom
    NVIDIA Windows 2000/XP Display Drivers
    PicaView32
    QuickTime
    REALmagic Hollywood Plus
    Realplayer Basic
    StyleXP
    Symantec Ghost
    VERITAS RecordNow DX
    VobSub v2.16
    WinAce Archiver 2.0
    Winamp
    WinMX
    WinRAR archiver
    Winzip
    [** Hardware installed according to 'Device Manager' **]
    Display Adapters--> NVIDIA RIVA TNT2 Ultra
    DVD/CD-ROM Drives--> PIONEER DVD-RW DVR-104
    TOSHIBA DVD-ROM SD-M1212
    VIRTUAL DAEMON TOOLS SCSI CdRom Device
    IDE ATA/ATAPI Controllers--> Intel(r) 82801BA Bus Master IDE Controller
    Primary IDE Channel
    Secondary IDE Channel
    Network Adapters--> Intel(R) PRO/100+ Management Adapter
    Intel(R) PRO/100+ PCI Aadapter
    Processors--> Intel(r) Pentium(r)III Processor
    SCSI and RAID controllers--> STEALTH SCSI Controller
    Sound, video and game controllers--> Audio Codecs
    Creative AudioPCI (ES1371,ES1373) (WDM)
    Game Port for Creative
    Legacy Audio Drivers
    Legacy Video Capture Devices
    Media Control Devices
    Video Codecs
    System Devices--> ACPI Fixed Feature Button
    Direct memory access controller
    Intel(R) 82801BA LPC Interface Controller - 2400
    Intel(R) 82801BA/BAM SMBus Controller - 2443
    Intel(R) 82801BA/CA PCI Bridge - 244E
    Intel(R) 82802 Firmware Hub Device
    Intel(R) 82815 Processor to AGP Controller - 1131
    Intel(R) 82815 Processor to I/O controller - 1130
    ISAPNP Read Data Port
    Microcode Update Device
    Microsoft ACPI-Compliant System
    Motherboard Resources
    Numeric data processor
    PCI bus
    Plug and Play Software Device Enumerator
    Programmable interrupt controller
    System board
    System CMOS/real time clock
    System timer
    Terminal Server Device Redirector
    [** Processes running according to 'Task Manager' **]
    EXPLORER.EXE
    SVCHOST.EXE
    SVCHOST.EXE
    StyleXPService.exe
    SVCHOST.EXE
    SVCHOST.EXE
    Icq.exe
    CTFMON.EXE
    LSASS.EXE
    SERVICES.EXE
    WINLOGON.EXE
    CSRSS.EXE
    NVSVC32.EXE
    MDM.EXE
    SMSS.EXE
    GEARSEC.EXE
    ALG.EXE
    DAEMON.EXE
    SPOOLSV.EXE
    wuauclt.exe
  2. A good question is how many good discs did you burn using Win98 and how many bad discs have you burnt with XP? Also, what media are you using? Have you tried different media, perhaps some high quality Apple or Pioneer media? I know that I had similar problems with a batch of DVDPro media I got from SuperMediaStore and the discs were very hit or miss and had problems like the ones you are describing.
    ABEG
  3. Sorry to ask a silly question, but have you done a XP update. It is well know that Xp has issues with burners. I solved my problems with the update on Microsoft site.
    Hope it helps......
    Ian
  4. Hey
    I burned 2 successful discs on Win98 and none on WinXP.
    And my Windows is updated with all the updates available on windowsupdate.
    Any other ideas? I'm getting really desperate.
  5. Nope
    Tried that. Still no go =/
    Any other ideas?
  6. Again, I would recommend trying different media. What media have you used thus far? Two succesful burns doesn't necessarily mean that the media is fine. As I mentioned in my previous post I had a 25 pack of media that was very hit or miss with half of the discs not working correctly.
  7. A couple of suggestions.
    Check to see if XP's UDF is turned on. If it is, turn it off and use the UDF software that came with the drive or RecordNow. The UDF and Wireless network drivers that come with XP are utter crap.
    When authoring write the VIDEO_TS & AUDIO_TS files to your hard drive and use RecordNow to burn them to DVD. This solved a problem I have with Ulead DVD Workshop and my HP DVD200i drive when burning direct to DVD.
    May 2001
    You basically have answered your own question. If the disks cannot be read by a settop player, but can be read by the recorder, then there is a 99.9% probability that the media is bad. Try burning something with a quality disk, like Pioneer, Apple or Verbatim. If this burn is successful, then you are in the 99.9% probability window.
    Look at the disks you are trying to burn. If you see "waves" in the dye coating, then these disks are most likely crap.
