I tried to burn a movie in VCD form using Nero and came into this problem:
It said
MPEG1 instead of MPEG2
Invalid video stream 29.97seconds 352x240
MPEG file is not suitable for SVCD
Turn off compliance
or
Reencode file video?
What should I do at this point, which one do I chose to burn the SVCD?
Oh, btw I checked the nero help file and it said that I need to d/l mpeg2/SVCD plugin in from their site. Do I need to get that?
try looking at ths "what is " options to the left will explain alot.
Where are you talking about??? there is no What it is anywhere on the page...
Can someone please answer this simply question??? -
I think what crusty is talking about is the FAQ - it wil possibly answer your question. Anywaz..
What Nero is basically saying is that the video file you are trying to burn is not a 'standard' for the SVCD Nero template that you are trying to use. (I assume) Try the VCD template option rather than SVCD as it looks like your source file is an MPEG1 file (VCD) and not MPEG2 (SVCD).
Try that first - if it still asks then look at the FAQ to get the 'standard' for VCD correct - do not let Nero re-encode unless you really have to coz it's not all that clever...
TeeeRex -
Well that's the whole problem, I need to burn a SVCD I have no problem burning VCD...What do you suggest?
Just select the SVCD template in Nero !?
Make sure the source is a SVCD MPEG though or you're completly wasting your time and CD's... -
Dear HardBody6Pack:
On the left side of your screen in the upper left hand corner, just below the VCDHelp icon is the title "What Is". Just above the "VCD", "SVCD", and "DVD" options.
The gurus are telling you to have a MPEG-2 file to make an SVCD, and a MPEG-1 for VCDs.Hello. -
Ok, I finally understand. I was tryng to convert MPEG -1 to SVCD and that is not possible. Thank you. That makes sesnse now.
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 12:59 -
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 10th Apr 2009, 00:56 -
Nero converting vob to avi,,,files way to big after????
By jcurrieirocz in forum Video ConversionReplies: 7Last Post: 17th Nov 2008, 20:41 -
converting nero video files to wmv
By chuckaug in forum Video ConversionReplies: 3Last Post: 11th Oct 2008, 13:18 -
Converting with Nero Ultra 7
By Nitro89 in forum Video ConversionReplies: 5Last Post: 21st Jun 2007, 13:42
