sorry if this is in the wrong section, i dont know where it should go so i thought i put it in the newbie section. Currently i dont have any aspi installed on my comp because i experienced some problems with it before. The problem is that b4 when i use aspi smart ripper rips dvds at a speed of .1x and .01x. Probably had something to do with PIO and DMA option of the cd drive. I had to format my computer a few time to fix this. Dont know how i fixed it but smart ripper rip faster now, about 2x. Also i notice that vcd easy making the .bin file takes very long time too. I saw it report no aspi on the bottom right corner. So i just wonder will smart ripper rip faster or atleast the same speed now if i install the latest aspi layer. Also will easyvcd work faster if i install aspi? thanks alot.
A working ASPI layer will not make your computer faster but will make
your IDE drives work properly.Try "ForceASPI" you can find it at sourceforge.com -
i'm searching the site for it. But just out of curiosity what this do? how is it differ from the aspi from adaptec.com? thanks for the infos
It installs basically the same thing. The difference is that the Adaptec installation sometimes doesn't install properly.
Regards.Michael Tam
w: Morsels of Evidence -
i couldnt find out where it is on the site could you give me a link to it thanks
You can download ForceASPI from http://www.doom9.org
Regards.Michael Tam
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 12:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 16:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43 -
ASPI for XP x64
By HartsVideo in forum Video ConversionReplies: 12Last Post: 6th Jul 2008, 05:20
