Hi. Newbie alert![]()
OK. Just got to grips with Virtual Dub and TMPGEnc.
My question is.....
I want to capture from a source that is PAL widescreen 16:9. (Actually it is from an ITV Digital box which broadcasts in widescreen. Any progs that are 4:3 are broadcast with black bands at the sides).
What is the recommended resolution for capturing this source.
I done the math and came up with 720x405, but I get an error saying unsupported function
I will be encoding to SVCD and want to watch the video as widescreen (Is this possible?????)
Thanx
Starhawk
Results 1 to 9 of 9
Originally Posted by crusty
Sorry for my ignorance. I am a genuine newbie
Thanx,
Starhawk -
vcd's and svcd's can't be made "widescreen" as such. you might as well just capture the whole image from your TV and leave in the black bands... that way when you play back the disc on your TV you'll get the same black bands at the top and bottom and you can select "zoom" mode or whatever on your TV.
MarkSwim with me
And we'll escape
All the trouble
Of the present age
Finally free -
Assuming you plan to watch it back on a widescreen telly, and that your source is anamorphic widescreen, then yes, it is possible to make a widescreen VCD or SVCD. Just capture the fullscreen image from your digibox at:
480x576 for SVCD
352x576 for VCD (needs to be deinterlaced and scaled to 352x288)
Encode it to MPEG using TMPGenc's VCD or SVCD templates. Keep in mind it will look completely wrong when viewed on your PC monitor, but played back on your TV in wide mode, it will look just fine.
For 4:3 material, your digibox should have a menu that allows you to switch off 16:9(anamorphic), which will remove the black sidebars from 4:3 programs. -
Originally Posted by Supremus
MarkSwim with me
And we'll escape
All the trouble
Of the present age
Finally free -
I capture in 16:9 anamorphic from a Sky Digibox. I imagine that the ITV Digibox gives a similar picture output. Just cap at 704x576 and use TMPGenc to re-encode to whatever output resolution you want. To go 16:9 anamorphic keep the source as 4:3, to go 4:3 letterboxed select source as 16:9 display.
which resolution for 32" widescreen?
By iancur in forum Video ConversionReplies: 1Last Post: 2nd Feb 2011, 13:48 -
42 inch plasma widescreen (16x9 hdtv has native resolution 1024 x 768 (4x3)
By sbt5 in forum DVB / IPTVReplies: 15Last Post: 4th Aug 2009, 21:59 -
vertical resolution of anamorphic widescreen?
By Sean_ve99 in forum Video ConversionReplies: 12Last Post: 7th Jan 2009, 11:41 -
PLASMA resolution..1024x1080 (or 1024x768) ..surely isnt widescreen?
By snadge in forum DVB / IPTVReplies: 6Last Post: 2nd Sep 2007, 11:24 -
My widescreen slashes resolution
By seragx99 in forum Video ConversionReplies: 1Last Post: 5th Jul 2007, 02:38
