i read on this site that someone named Mike has a Philips DVD player 825, and to be able to fast forward or rewind VCDs he upgraded his DVD player witha firmware disc version 9.23, i upgraded my DVD player with the 9.28 version and wasn't able to fast forward or rewind, i want to know if i need to use the 9.23 version upgrade disc instead of the 9.28 version to be able to fast forward and rewind, thank you!
I just updated my bios as well...and I can fast foward and rewind (sort of). Use the yellow "left arrow" "right arrow" buttons instead of the normal ff rw. It's choppy, but it works! Tested out in VCD, don't know about SVCD as of yet.
~build a man a fire, keep him warm for the night. Set a man afire, keep him warm for the rest of his life. -
To enable FF & RW on a phillips player your mpeg file has the have sequence headers for each GOP before you author it to VCD. Tmpgenc does this by default, I think Xing has an option, and panasonic doesn't support it.
There's also a tool on the tools downloads that will insert the sequence headers without re-encoding the stream. That, and the updated firmware should let you ff & rw.
Another benefit to having the sequence headers in place on the 825, is that without them it will restart or skip to the next track when it encounters an error in the mpeg stream. With sequence headers in place it just skips to the next GOP.
There's also an option in the 825's setup menu to disable PBC, which will let you see the time index but will probably break your menus. It doesn't stick, so if you power off the player it defaults back to enabled. -
i can ff and rewind just fine on my phillips 825 with all my vcd's i have made.
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 16:06 -
PHILIPS DVP642... how do I upgrade the firmware?
By mummer43 in forum DVD & Blu-ray PlayersReplies: 39Last Post: 14th Jan 2009, 18:45 -
Philips DVP5965k/98 modified firmware?
By chongbian in forum DVD & Blu-ray PlayersReplies: 4Last Post: 27th Nov 2008, 00:59 -
Philips HTS3450/37 Firmware????
By ezdell in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Nov 2007, 15:20 -
Philips DVP5900 DVD player firmware upgrade for HDMI - need help
By s_poisk in forum DVD & Blu-ray PlayersReplies: 1Last Post: 24th Oct 2007, 08:41
