anyone knows how may bitrate(kbps) in 100 MB? someone show me how to calculate it?![]()
"Never trouble trouble, til trouble troubles you"
bitrate(kbps) = total filesize(bytes) / Time of video(seconds).
8 bits = 1 byte -
Do you mean a file that is 100Mb in sise (which can be tranfered at any bit rate) or do you mean a file that is 100MB per second, which is 800Mb/sec or 800000Kb/sec.
what i mean is that i want to fit a 100 MB of mpeg on a CD-R and i want it to be as highest quality (in birate -kbits/sec) as possible without going over 100 MB after the conversion. Pretty hard to explain what i mean...sorry if its not clear enough...thanx for the help anyway!!
"Never trouble trouble, til trouble troubles you" -
Bitrate is allocated per second so it all depends on how long your movie is. There is no bitrate setting that will always result in a 100MB file. Use Kdiddy's equation, it works.
Take out a calculator!
As what Kdiddy said -- bitrate = size / time
Regards.Michael Tam
w: Morsels of Evidence
Question about Premiere Pro's aspect ratio math
By Asterra in forum Newbie / General discussionsReplies: 3Last Post: 1st Jul 2011, 09:15 -
Math: Equation / Formula questions
By vhelp in forum ProgrammingReplies: 7Last Post: 27th Jul 2008, 17:06 -
math problem help?
By lordsmurf in forum Off topicReplies: 4Last Post: 26th Feb 2008, 00:52 -
Math Question Regarding Aspect Ratio
By Krelmaneck in forum Video ConversionReplies: 10Last Post: 28th Sep 2007, 01:08 -
Is This Bad Math or Simply SOME Nerd Calculation?
By moviebuff2 in forum Off topicReplies: 6Last Post: 14th Jul 2007, 09:28
