I was trying to convert my 13 ghosts rip, which is 668 megs, to vcd format in TMPEG and its not even half way done and it says the file is 830 megs? I'd like for this to fit on a regular 80min cd or atleast 2... what should I change around in my settings?
Hi
You have got ot use a bitrate calculator.
There is a simple but good one right here on this site
http://www.vcdhelp.com/calc.htm
hope that helps -
Standard VCD will mean 1 CD for every 79-80 minutes. So, generally a 1 CD DivX will convert to a 2-CD VCD.
[Help] Problems creating VCDs.
By scott274 in forum Newbie / General discussionsReplies: 77Last Post: 15th Jul 2008, 03:43 -
Multiple VCDs in one DVD
By vid_n000b in forum Authoring (DVD)Replies: 27Last Post: 30th Apr 2008, 03:52 -
Big big troubles with firewirre PCI card.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 1st Mar 2008, 00:51 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 11:38 -
I can not play some VCDs on my mechine. Can U help me ?
By wapw in forum Software PlayingReplies: 2Last Post: 21st Aug 2007, 12:46
