This probably is an easy question, but i cant find the answer to it.
What is Progressive Scan and what are the advantages to having it on a DVD Player?
Thanks if you can help.
Click this link, then to a <Ctrl-F> and search for "progressive":
http://www.dvddemystified.com/dvdfaq.htmlAs Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
The Laymans Answer: It provides for a better image over those DVD players w/o Progressive Scan. You will need a digital TV however that accepts a progressive scan input from the DVD player in order to use this feature.
What is Pan and Scan?
By janlafata in forum Newbie / General discussionsReplies: 7Last Post: 15th Jan 2009, 22:27 -
Laptop Scan Converter
By endlessnameless in forum Newbie / General discussionsReplies: 3Last Post: 17th Nov 2008, 18:28 -
Is there anyway to stop over scan?
By andre477 in forum Newbie / General discussionsReplies: 4Last Post: 25th Oct 2008, 15:20 -
How to scan for any errors?
By Kwan in forum Newbie / General discussionsReplies: 6Last Post: 1st Oct 2007, 07:59 -
under scan
By devdev in forum Newbie / General discussionsReplies: 1Last Post: 30th Aug 2007, 16:42
