Can anyone tell me if I can create a VCD with a DVD-R instead of a CD-R?
Originally Posted by MOVIEGEEK
The site above says
DVD-VCD
Standard DVD support MPEG1 so it is possible to author VCD MPEG files to DVD without reencoding the video, on one standard 4.7 DVD-R,DVD-RW or DVD+RW disc you can store about 450 minutes VCD MPEG. But the DVD standard requires 48 khz audio(VCD is 44 khz) so it requires some preparation before authoring and burning the DVD.
Before trying to make a DVD-VCD you should first try your standalone DVD-Player to see that it supports this format. Remember that on some DVD-Players you may have to change audio settings to get any audio. Download a DVD Sample here with a DVD-VCD sample that you can burn and test.
And for transfering SVCD to DVD-R:
http://www.vcdhelp.com/svcddvdr.htm
BTW, can you make a "SVCD DVD-R" more compatible to a DVD player if you use the "change svcd header to vcd header" trick? http://www.geocities.com/newestmoviesencode/dvdvcdto put your SVCDs on one DVDR,DVDRW,DVD+RW, do not use it if you are converting from another source like DVD,DV,AVI or DivX.
DVD-SVCD
Standard DVD do not support the SVCD MPEG2 standard but you can anyway make some kind of XDVD without reencoding the SVCD that may work on some DVD Players. If you want real DVD reencode your SVCD to DVD instead.
In other words is the trick "media independent"? Should everyone always encode to SVCD rather than VCD and just apply the "header trick? When does the "header trick" not work on players that can play VCDs???
DVD to VCD... HOW?
By aglara in forum DVD RippingReplies: 3Last Post: 17th Jun 2010, 00:29 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 20:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Dvd to Vcd
By tryst1 in forum Video ConversionReplies: 2Last Post: 5th Jun 2007, 02:30 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
