Using VCDEasy I made an SVCD with a menu and two different movies. The menu works fine, the first movie works fine, but when I try to select the next movie(either by pressing "next" or "2" on my remote control) it seems to get stuck in the process. It will show that the second movie is playing and the counter counts in 5 second intervals. Nothing displays on the screen. The only time i got it to work was when i hit fast-foward, then it showed the movie in fast-foward and then i hit play and it worked fine. I dont want to have to do that everytime though. Any Advice??
There's most likely a glitch right at the start of the video. It could be with the original source, or just on the CD. Try just burning that movie to a disc and see if it works.
The menu works fine
You sure it does ?
Sounds like when your pressing for the next movie its not doing anything ?
Need some quick help with IMGBurn
By flyin-lowe in forum Authoring (DVD)Replies: 4Last Post: 8th Dec 2010, 20:20 -
Quick Hello :)
By Paul Iddon in forum Newbie / General discussionsReplies: 1Last Post: 17th Feb 2010, 18:14 -
Windows 7 quick launch problem
By mysts in forum ComputerReplies: 6Last Post: 16th Oct 2009, 01:34 -
Quick AVI Creator problem
By CSULB71 in forum DVD RippingReplies: 14Last Post: 12th Jun 2008, 17:01 -
quick question?
By JRSWIFEY2004 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jan 2008, 17:38
