This question may have been asked before but didn't see it anywhere. I am trying to encode to MPEG1 for VCD from an AVI file using TMPEnc's VCD NTSC template. Most of the time the picture looks pretty good, but when there is a contrast change, motion, or a very busy (detailed) shot, the picture pixelates.Is there a way to increase the quality of encoding to fix this? I've messed with GOP settings by increasing them, but it did not seem to effect anything. Any suggestions would be appreciated.
well i hate to say it but it really all repends on the source. The motto around here is
crap in = crap out
you can enable soften block noise, under the quantize matrix tab under settings. This will help some. Also you might want to look into enableing noise reduction under the advanced tab. Doing so will increase encoding time, but you can probably help out the picture more.
converting .mov to flv pixelating and jumpy
By Leonski in forum ffmpegX general discussionReplies: 1Last Post: 1st Oct 2010, 11:55 -
DVD backup - Intermittent freezing with pixelating
By Nordo in forum DVD RippingReplies: 3Last Post: 21st Feb 2009, 23:03 -
Help with video breaking up/pixelating
By enigmatic in forum MacReplies: 1Last Post: 27th Nov 2007, 05:45 -
Please Help! DVD-R disc are freezing/breaking up and pixelating.
By elove in forum MediaReplies: 19Last Post: 19th Sep 2007, 10:02 -
Old DVD's are pixelating?
By jlburn07 in forum Authoring (DVD)Replies: 2Last Post: 11th Jun 2007, 01:17
