Is It Possible
I Have Managed To Extract The Video, but everytime i try to get the audio i can't seem to get it. and once i have got it what do i do next? just encode with Tmpeg? i can out SVCDs and VCDs To DVDr, So i have an understanding. And Will The AC3 Be On The DVDr? and another thing the divx is 2 disks
OPen your divx file with virtualdub. Select Audio->direct stream copy, File->save wav. This will take a few mins (depending on your PC). You will now have a file on your HD called myfilm.wav. Rename this to myfilm.ac3.
Encode your video to whatever format you want, ignoring the audio.
Use Spruce to author, supplying tour encoded video file and your ac3 file for audio (see the guides for help on using spruce).
AFAIK, spruce is the only DVD authoring proggy that will accept an external AC3 file, unless you want to spend several thousand dollars anyway.
Hope this helps.
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
MPEG4-AVC (H264) + AC3 -> Divx + AC3?
By thomas_fogh in forum Video ConversionReplies: 12Last Post: 1st Nov 2008, 20:25 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19
