I have a few mpeg files im tryign to compress to avi files and for some reason i keep getting sync errors. It can compress about 30 mins of video then i get the sync error. I tried compressing a friens episode and i didnt get a sync error but the sound came out all distorted; the video was going in real time and the audio was going in slow mo.
I guess you selected a codec for the AVI, possibly a DivX, but did you also select a codec for the Audio ?, and if you did, did you select one that matches the frequency of the original mpeg (Possibly 44.1Khz) and did you select a bitrate of high quality or a very low one.
This is tlhe setting I had it in
Video-Divx MPEG 4-Fast Motion
Audio- Divx Audio 64 kbps 44khz stereo for divx -
Yes but you talk about 2 problems, one being the audio out of sync, and another producing bad audio "distorted" "Slow"
What is the original mpeg ?
If you did manage a convertion without a sync error, then you only need to work on the quality of the MP3 "64 kbps 44khz" 64 might be too low, is the original 44.1Khz or 48Khz ?
problem with compression using virtual dub
By jpez1 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2010, 14:24 -
no options in audio compression for virtual dub
By jonbaker in forum AudioReplies: 9Last Post: 14th Feb 2010, 20:00 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 14:48 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 16:36 -
Virtual Dub Mod
By OG24 in forum Newbie / General discussionsReplies: 11Last Post: 8th Aug 2007, 16:36
