I have many movies burned to vcd. Many of them are no longer on my computer. If I simply want to make a copy of a vcd in my collection, please tell me if these are the simple steps. First transfer the vcd to the hard drive, then simply use Nero to burn it as a vcd? Seems too simple! Also, how much quality is lost from this new copy? Thanks, all in advance.
What you have to do is get yourself a copy of VCDgear.
Then you want to copy the .dat file in the MPEGAV folder on the VCD to your hard drive.
With that you want to convert the .dat file to an MPGusing the VCDgear program.
Then you can simply burn with nero or whatever you wish to use and there will be no quality lossed becasue its pure digital
Hope this helps
PS get VCD GEAR at www.vcdgear.com
-LAMBERT -
Eh, u drunk? Just copy the avseq01.dat file to your pc. Rename it to file.mpg. Drag this into nero and burn. VCDGear is not required
Uh yes you could do that but then there is a possibility for error.
I read somehwer on here that if you just rename it i could thoeretically screw up. It rarely happens but still could happen.
I just though it would be on the safe side because VCD Gear actually has the option to comvert it and i just did not want this guy to have anymore problems. -
Why don't you do a simple disk to disk copy, if you only have 1 CD-ROM set the source and destination to be the same, you will be prompted for the blank disk after the source has been read. Nero, CDR-WIN, Juggler they all do simple disk to disk.Originally Posted by after_science
@KingJohn
I was thinking about that but the title of the post said he wanted to go to hard drive. -
you can't just copy the dat file when you got menus, would be great to know if there is menus
"vcd to hard drive to vcd" you missed the > VCDOriginally Posted by poonaner
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 20:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 19:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 14:42 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 12:06 -
Replace Dead Hard Drive From DVR 533HS With Working Hard Drive From DVR 640
By gordo1811 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Dec 2007, 16:58
