I was about to purchase the PRO when my 2.53 started having an Illegal Floating Point Error.I have read articles about turning OFF the SSE & SSE2 but that causes the encoding time to double (or more). What is the point of having a nice P4 if I cannot use its full power.
What is going on here? These are NTSC DVD rips. I have successfully used 2.53 to encode non stadard VCDs based upon the KVCD templates.
IN FACT, I have encoded the same video several times and got the ERROR when I made a reduction in MAX bitrate to make the file smaller. Here is what happended:
1) 704x480 29.97fps CQ 50 300-1500 44k 128kbps.mpg WORKED! File 831MB
2) 704x480 23.976fps CQ 50 300-1440 44k 128kbps.mpg WORKED! File 731MB
3) 704x480 29.97fps CQ 50 300-1440 44k 128kbps.mpg ERROR! File ??MB
What is happening?
Thank You & Have a great Day! :)
reman -
Normally this happens when TMPGENC hits some junk frames, or at the end when video finishes and there is some audio left
Since it is not at the end I would rule out the audio part. 8)Originally Posted by KingJohn
Junk frames? Why did it encode the other 2 times? If it is that problem, how do I analyse the VOB files?
reman -
I also have the P4, and TMPGEnc only gives problems with some junk frames. Did you do the DVD rip, or did you download it ? If its one you have downloaded, then I guess that is the problem.
If you do a normal encode without changing anything (template) does it still crash ? -
NOT downloaded, DVD rip. I will try the normal templates.Originally Posted by KingJohnThank You & Have a great Day! :)
reman
Help - invalid Floating point operation!!!!
By Pintocas in forum AudioReplies: 1Last Post: 15th Sep 2010, 10:28 -
r6002 floating point error with MPC , maybe
By BWMagus in forum Software PlayingReplies: 5Last Post: 19th Mar 2009, 09:08 -
MPC Runtime Error, 6002 floating point support not loaded.
By Leo99 in forum Software PlayingReplies: 5Last Post: 24th Nov 2008, 03:22 -
Illegal Disc error
By smackypete in forum Authoring (DVD)Replies: 10Last Post: 19th Jun 2008, 20:00 -
Illegal Disc Error
By ScottM808 in forum DVD & Blu-ray WritersReplies: 25Last Post: 12th Jul 2007, 15:51
