ok I wasted 4 CD's last night so im pretty pissed now..I have a .AVI movie that i sucsessfully converted to .MPG last night, the only thing is that it wont play on my dvd player, but it plays fine on my CD-ROM, I've tried a few different things from looking around on this site but its still the same outcome,, A wasted CD! anyone have any ideas? oh yeah,, I used VirtualDub and TMPGEnc to convert..Thanks!
first question would be are you converting the mpg to the vcd format using a product like nero, cd creator, etc.? The chance of your dvd player(I am guessing stand alone) playing a native mpeg without using one of these products to convert it to a vcd/svcd/cvd, etc.?
As far as being "pissed" for wasting 4 CD's. All I can say is you better start scouring the best buy ads for deals on CD's your are going to have A LOT of coasters if you start into VCD creation. -
yeah i forgot to put that in last bit of my message,,, I did use Nero to complete the process to VCD format,, I have already made two VCD's using movies that were already in .MPG format when i downloaded them, and they work fine...this .AVI on the other hand isnt working out too well,, I also noticed that when i do stick this not working VCD into my standalone DVD, a bunch of folders comes up on the screen, the other ones that do work dont have these popping up
ah! You have to convert the AVI file over to an mpeg file. I believe that nero can do it for you (I'd recommend TMPGENC - in tools section) to convert it to an mpeg.
Is the file that you have a TRUE AVI. A lot of divx files have an extension of AVI, but it is not a true AVI file, but rather a HIGHLY compressed video format (mpeg 4, I believe).
An easy check is that if it is a movie(70+ minutes), check the file size. If it is under/around 600 meg, there is a good chance that it is a divx.
When you convert whatever AVI file you have to mpeg, you should be able to burn it using nero. -
what was the steps you used in nero to burn the mpeg file to a usable SVCD or DVD... I get nero to burn but i have something screwy happen after it is completed...
Dex 8) -
My files are in a compliant vcd mode (320x240 1150 bit rate) and i open nero up and click on vcd (actually all of mine now are non compliant SVCD - I now do CVD which is to me a much better picture,etc.) and then go to burn, pull the file in, nero does its little check thing and then I burn it.
When you dump your mpeg file into nero and it checks it (VCD), does it tell you its out of compliance at all???? VCD is very "you must have it this way or else". SVCD, however, is a little more friendly with messing with stuff.
I was surprised an ip masker really really worked
By yoda313 in forum Off topicReplies: 0Last Post: 22nd Feb 2011, 15:49 -
I have tried many media converters for HD, none of them worked
By calande in forum Video ConversionReplies: 2Last Post: 11th Jul 2010, 21:02 -
renamed .mp4 to .avi and worked
By eeyaphew in forum MacReplies: 0Last Post: 8th Apr 2008, 20:09 -
.MKV to DIVX worked but not really
By cabala in forum Video ConversionReplies: 7Last Post: 7th Oct 2007, 19:58 -
Mkv extract... worked once.. now flawed!
By Mushmello in forum Video ConversionReplies: 2Last Post: 1st Jun 2007, 12:22
