    Jul 2002
    Scotland
    I keep having a recurring problem. When I use any ripper either for dvd or audio cd's, I get a error.
    the screen goes blue and the following message is displayed.
    Disk write error to drive c:
    Data may be lost.
    Hit any key to continue.
    The program will then start up again but the data files can either be broken or corrupted.
    This problem has happened on two different computers which I own.
    Thanks in advance.
  2. something you have on them (some software probably) is causing a conflict. Have you defraged your hardrive lately?
    Jul 2002
    Scotland
    All i have installed is power dvd, dvd decripter and dvdx.
    I usually defrag the hard disk after every error.
  4. have you tried clad to rip?
